Dave's 914
I have a confession and I want to share my experience with the board. This board has renewed my interest with my teener and made me want to enjoy my car more. I have owned my car for over 25 years, completed my restoration 15 years ago and I have only driven the car 4400 miles enjoying the occasional weekend drive, car show or trips to the Pomona swap meet. I consider myself a competent mechanic- I have built many projects and been wrenching since I have been 13 years old. I'm turning 50 this year. My car mainly sits in my shop as it’s been a full concours q-tip garage queen as I’ve just never been happy with its driveability - off idle response could be better; the number one cylinder seemed weak with idle tuning etc. The engine is a 2.0 with euro P/C’s and 40mm Delorto carbs. Lately I installed a CD ignition and that improved things a bit. Last night, I was down at my shop and thinking about this and having a few beers (beer = clear thinking!)
The facts:
• In playing around with my idle mixtures screws, number one cylinder was the weakest-
• The number one cylinder is the furthest away from fuel flow
• I checked the idle circuit and passages in that side of the carb- clean no obstructions
• I decided to check fuel pressure- I am running a 914-6 fuel pump and a cheesy aftermarket fuel pressure regulator- the regulator was set at 3-4 psi, the optimal pressure for carbs.
So, I set up a pressure gauge on the fuel line feeding the suspect carb and find ITS ONLY PRODUCING BARELY 2 psi!
I cranked up the pressure regulator all the way up and got 3.5 psi – (the 914-6 fuel pump I’m sure is internally regulated) and now the engine runs fat and happy! I took the car for a spin and could not believe the difference. Off idle response is smooth and powerful. I’ll re-time and tune for more improvement.
With carbs, most of your regular driving is done off the idle circuit until closer to WOT so, here I’ve been compromising things for fifteen f’n years!
And I thought I had my act together- call me a stupid shit! Now, I don’t want to hear anything from you guys about staying with factory fuel injection….
This weekend I'm going for a drive.
Regards, Dave Hall
