I decided to clean, inspect and repack my CV joints before th trip to the RRC. First axle had one joint that was ok.... questionable but ok..
The second joint was fried. the inner bearing carrier was smoked with gouged rough pockets where the bearing was riding. I took a joint off a spare axle and cleaned it up.
After I reassembled the joint I really can't move it. You know, slide it in and out or rotate it. It's kind of stuck. No grease on the joint though.
Q) Can these be assembled wrong causing the joint to be too tight?
Q) How tight is too tight with no grease?
The first joint is very fluid and will come apart again easy. The second joint is stuck and I think I can get it back apart but it is going to take some work.
