Will above ignition box work with a Bosch Blue Coil?? I have mallory UniLite D.
What other items are needed to make the box work on the 914?
Anybody got pics of their installs?
As always THX in advance Ken
Mark Henry
Sep 8 2010, 11:21 AM
I believe it will, but you should get the high voltage MSD coil, it's the cheap part of the system. You will also need a MSD tach adapter to run the stock VDO
ConeDodger
Sep 8 2010, 11:41 AM
QUOTE(Mark Henry @ Sep 8 2010, 09:21 AM)
I ran just that. MSD 6AL 7000rpm pill, Bosch Blue, no tach adapter. Got tack signal directly from the connection on the MSD. In fact, I have a new tach adapter sitting in the garage. Didn't need it.
7275914911
Sep 8 2010, 12:02 PM
From digging around search it appeared to me that it WOULD work like Rob says.... ie. MSD...Bosch Blue...No tach adapter
I was going to use the 6000 pill. But on that note.... I am not sure were my Red Line should really be? I have 9.3 CR with 9550 cam.
Charlie...it is a 2056 build. Stock is 5800(?) on the 2.0 liter....
charliew
Sep 8 2010, 12:12 PM
I hope you are talking about compression ratio on a water cooled motor. A stock valve spring sbc will not like anything over about 5800 especially if it's a roller cam motor.
