The double red light at the top of the fuel gauge is blinking. I just replaced the fuse panel with an engman kit and it fixed quite a few of my problems, but now the light is blinking.
Is this the oil pressure light? I don't remember since my car hasn't been running in so long. If so would it flash for anything else? Emergency brake? I pressed the ebrake switch in and it didn't stop, but I didn't take it out and unplug it or connect it to see if that fixed my problem. Is there anything else that it could be?
If it is the oil pressure switch is there a way to test it? Check continuity?
The new fuse panel fixed my charging problem, dash lights, blinkers, and made my tach quit bouncing all over the place so I'm really happy with the purchase. I still need to clean up the wire routing and screw it back to the dash, but it's almost done. Anyway I'm almost back on the road.
