QUOTE(Cupomeat @ Sep 13 2010, 11:15 AM)
Play on the guide tube is not an indicator of wear as they don't really wear there. Also, the throwout bearing blocks do wear, but if they are tight, don't replace them.
Now, as for the actual bearing wear, does the center part of the bearing smoothly rotate and have minimal lateral play? If so, it is probably fine. It can be repacked by hand, or with a bearing packer if you want (and probably recommended)
In the old days they were good for 100k miles, and given what mileage we put on our 914s these days, it will probably last forever.
I hope that helps, and post a picture of your car!
Thanks Eric, now I know that the center ring should spin LOL. I just cleaned off all the crud and some further cleaning with a brass wire wheel the center ring now spins freely, has no lateral play and the bearing seem to be pretty quiet while spinning. I don't have a bearing packer, do I just force as much grease by hand as I can around the ring? Do I grease the guide tube as well when reinstalling it back on the trans?
This is my first car project. Like I said the car has been sitting for 10 years in my garage and I have no idea how long it was sitting in the sellers garage. My wife for the first time in 10 years said "DO SOMETHING WITH THAT CAR OR I WILL!" Then I found this forum, was completely inspired, and started working on it. Its pretty scary looking at this point. Plus I'm doing a SBC conversion so I have been cutting and grinding and, well, you know the drill. Its not much to look at yet. I will post pics as soon as I have something worthy to show.
