QUOTE(jasons @ Sep 13 2010, 05:59 PM)
I know zinc/galvanized is bad. Since Ospho is just Phosphoric Acid, I doubt Zinc is much of a concern.
I remember someone posting a link to a custom bicycle frame builder that became temporarily paralyzed from some kind of solvent fumes when welding. Anyone else recall that?
People tend to use the trade name "Ospho" as a generic name.
But formulations are different. If you look at the MSDS for "Ospho" (brand) you will see that it is just Phosphoric Acid, so it converts the iron oxide into iron phosphate. Another product is the brand name "Metal Ready" (by POR15). In addition to Phosphoric Acid, it also has Zinc Phosphate. Which I believe is what the original poster is asking about. I use the Metal Ready brand and I just make sure I have some type of ventilation when welding.
Regarding the solvents and welding... That is when you weld around chlorinated solvents (such as used in brake cleaner). The UV light from the arc converts the chlorinated solvent into phosgene gas (used in WWI as a poison gas in trench warfare)
This is why I used non-chlorinated brake cleaner.
