This morning on my way to work the check engine light came on in the Jetta.
The car seemed to operate normally, so after i got to work i took one of our CarChip OBDII loggers, plugged it into the OBDII port and went for a short drive.
When i read out the trouble code it said:
P0455 Evaporative Emission (EVAP) System Leak Detected (large leak)
I goggled the code and found a post on a bbs where someone mentioned:
"The most likely cause is a loose or poorly fitting gas cap."
Which rang a bell as my GF told me this morning she had filled up the car last night before coming home.
So i walk out to the car and check on the gas-cap, and sure enough, it wasn't all the way on!
Easy fix.
Now, how do i clear a DTC code?
Andy
