QUOTE(damnfiknow @ Sep 14 2010, 06:40 PM)
I'm in the final stages of a transmission rework and have an unused washer/spacer. Can't determine where I have left it out. It is 46mm OD, 34.5mm ID and 4.25mm thick. Its thicker than any of the common flat washers and is a not what the good Doctor refers to as a thrust washer. Pelican's drawing of the Pinion shaft describes the washer between the shims and 5th gear as "Spacer washer". As close as I can tell from the Dr Evil DVD, the washer that he puts in the space looks to be a common flat washer. I did come up short one flat washer and I used one from another transmission I have torn down. I thought I had just lost one on my bench. This could explain this if the thick one described above is actually suppose to be used at the shim point. Help..
You're not going to want to hear this,,,,,
You should tear your transmission apart again and double check the gear stacks, it's a pain, but you really need to have all the thrust washers in place. Take pics this time and me or another of the Doc's darkside deciples will chime in and point out how the gear stack should go together. I think the order is mentioned in the
good evil doctor's video.
-Robert
