Had issue with short in the FI wiring, where the FI would not work well, the car still started and I could keep it running. I removed the FI wire harness and the ECU and was checking other Electrical connections in the engine compartment and I now have nothing happening at the coil to generate spark???? Is there some thing that is needed from the ECU to get the ignition to work?
Figured since carbs can be used instead of FI that it could just be removed.
Thsnks for any guidance you may have
Irv.
