This is a 2.0 914 Engine which has been modified for full flow with remote oil filter and remote oil cooler. I'm a bit new to the type 4 engine and am looking for more information.
The oil temp sensor was originally "t-eed" with the oil pressure sensor near the take off for the oil cooler. I want to mount it somewhere else. I'm considering a taco plate but would like to avoid if possible.
I've attached a few pics. There is a block off plate (orange). I'm assuming this was for the integrated screw on oil filter......is this correct??
Right below that area there are what appear to be two case plugs that were replaced with screw plugs.
I was wondering where the lower plug goes, ie is this a good place for oil temp sensor?? Does this go into a passage for the oil filter from the pump??
Thanks for any help.Click to view attachment Click to view attachment
