QUOTE(qa1142 @ Sep 20 2010, 05:41 AM)
Stock '74 911T but this is what I think I want and how did you mount that without punching a hole in the gas tank?
I did it with the gas tank out. I used a plate about 4 inches square and drilled a small hole in each corner. Drilled a 1/2" hole in the center, slid a long bolt through and welded the bolt head to the plate.
Next I set the spare in the car and drilled a 1/2 inch hole through the center of the wheel through the firewall.
I slid the bolt/plate in from the gas tank side and used pop rivets to attach the plate to the firewall.
I use the OEM 964 jack that's in molded foam inside the wheel and there is still enough room above it to store tools inside the wheel.
The whole setup works pretty well and leaves the trunks with a little more room for gear.
