913B
Sep 19 2010, 10:11 PM
Any tips on how to remove the clips on the blower box housing. Is there a special tool that works good for the job ?
Thank you
dlee6204
Sep 19 2010, 10:16 PM
If I recall correctly, there are little holes in each of the clips. I used a snap ring tool and it worked nicely.
913B
Sep 19 2010, 10:27 PM
Will the harbor freight ones do or one from sears or something, I dont have access to snap on dealers
bandjoey
Sep 19 2010, 10:56 PM
My box is different. It has plastic titties on the top and bottom of the box that mate together, and a flat slide on spring clip to hold them together. I broke 1/2 of my box titties trying to get the clips off. They were tight and stuck on with age.
Next time I'll try a PB blaster soak, even though it's on plastic.
Tool in my case is a screwdriver. Suggestions?
Trying to find a pic to post.
Andyrew
Sep 19 2010, 11:07 PM
QUOTE(porsche913b_sp @ Sep 19 2010, 09:27 PM)
HF has those, they all pretty much work the same.
PS he said "snap ring" not "Snap On"
IronHillRestorations
Sep 20 2010, 06:14 AM
FWIW I wouldn't use PB Blaster anywhere near old plastic. That fresh air box and the front air controls are my favorite thing NOT to touch on a 914!
913B
Oct 1 2010, 07:26 PM
So I checked out the selection at HF, not so great. Does anyone have a specific one, model, brand and where you purchased it that has worked.
Thanks in Advance
Ted
Mikey914
Oct 1 2010, 07:37 PM
You should be able to get at any Napa store, or auto parts store with a decient inventory. Those are a pretty standard tool. As for soaking, you shouldn't have to. You can clean the plasic with a plastic cleaning compound, you should be able to find there. Most of the boxes are still in pretty good shape, just the nubs tend to break if your not careful.
I was wanting to do a complete rebuild thread on this if you want to take some pictures and post I'll throw in one of my rebuild kits free of charge. Just PM me.
jim_hoyland
Oct 2 2010, 09:45 AM
QUOTE(Mikey914 @ Oct 1 2010, 06:37 PM)
Good Idea! I'd like to see the in/out of this project.
913B
Oct 5 2010, 06:45 PM
I will try my best. Kinda intimidated, went over 23 pages of threads about blower box rebuild and almost every one of them say they broke something, hhhmmmm.
76-914
Oct 5 2010, 08:35 PM
There's a tool??? I just slid them on & off with screw driver and pliers.
McMark
Oct 5 2010, 08:38 PM
Not a whole lot inside. Take pictures as you go if you're worried about mixing anything up. But dive in. If you get stuck, just ask. I've don't a few, but never took pictures.
bandjoey
Oct 5 2010, 10:15 PM
QUOTE(76-914 @ Oct 5 2010, 09:35 PM)
Mine were so stuck on I broke several of the plastic tits getting them to slide off, even with lube spay.
Yep..a rebuild for the Classic Section would be great.
Mikey914
Oct 5 2010, 10:28 PM
Send me your shipping info if you want to do it. I'll provide the seals
