Thanks again y'all.
I almost got Punkin to the point of being able to turn the key
I found a thread that actually had 3 pictures showing the relay in question. From that I was able to disconnect that relay & connect the starter the normal way... (I hope
) There are 2 studs on the back of the starter along with the flag connector. I ran the red wire with the flat "O" to the stud on the left. Ran the other "O'd" wire to the stud on the right & the smaller wire with the female end to the flag terminal.
The wires that I thought were for the license plate lights weren't that at all
Before puting the engine in I pushed the wires for the thermo time switch, AAR & temp sensor thru a hole to get it outta the way. Well... I forgot I did that so it led me astray!
Punkin is back on the ground and all the wiring is complete. Next is the vacuum hoses. If I hadn't spent an extra hour cleaning up the oil I drained on the floor
(super dumbass attack) I think I may have been able to get it finished. Found out the wire from the thermostat is too short by 2 inches so will need to get "Jerry" to rig sumpin!
So, to make this long story, er ah, end... I'll just say
I still can't believe I took out the engine & tranny & got another back in
Simply amazing... Simply amazing
I luv this car
............b
