Why would i not want to use the stainless flex lines? It says they are better on the pelican site.
Of course it does, they are selling them to you.
http://www.914world.com/bbs2/index.php?showtopic=55559QUOTE
What about braided stainless flex hoses?
These are commonly available, and people like them because they give better feel. Or so they think. The actual feel difference between fresh rubber hoses and braided lines is actually pretty small, and the improvement people note is usually wishful thinking, or they're replacing tired rubber lines with fresh stainless lines. The danger with stainless lines is that they require more maintenance and attention than rubber lines. Stainless lines are a braided covering over a Teflon hose. The braid is usually exposed, and gets dirty. This dirt works itself into the braid and begins chafing the relatively fragile Teflon hose underneath. This most often happens at the ends of the hose, near or under the crimped-on fittings. Given enough time, the Teflon hose will fail, usually with no warning. The result is a brake pedal that goes straight to the floor. If a front line fails, it also means nearly zero stopping power.
Rubber lines also fail over time, usually by swelling internally or cracking externally. This deterioration is slow, however, and there is lots of warning in the form of bad pedal feel and reduced braking, or obvious cracks in the hose. This process can often exist for months, so you have ample warning and time to get the car home and replace the brake hoses.
Stainless hoses are fine for racing use, as racecars are little used and frequently inspected. For a daily driven car, however, you're unlikely to inspect your brake lines nearly often enough, and the failure modes for stainless lines are hard to detect in advance.
