KaptKaos
Sep 22 2010, 04:11 PM
I have an old Volvo that I need to replace the turn signal switch on the column. I have the new (used) switch, but I want to make sure it's clean before I install it. It has some gunk in there. Here it is:
Click to view attachmentWhat's the best way to clean this up to ensure good connections and operation? I had heard of people using CLR on bits like this, but I assume that it will take a while to dry if I do that? Others have said WD40, but I am not sure about that. Any sort of contact cleaner or something I should be looking for?
Let me know.
TIA
KaptKaos
Sep 22 2010, 09:03 PM
Bueller, Bueller, anyone, anyone?
Mike Bellis
Sep 22 2010, 09:07 PM
Radio shack or Fry's.
Buy contact cleaner and a tooth brush. after cleaning use TV contact lube.
KaptKaos
Sep 22 2010, 09:23 PM
Thanks Mike.
So nothing that immerses the part, right?
hot_shoe914
Sep 22 2010, 09:30 PM
I will have to check to see what kind it was, but contact cleaner on my relay board and all plug ins, relays and pins just fixed my '73 2.0.
cary
Sep 23 2010, 07:13 AM
CRC ......... in the black, red & white spray can. I get mine at NAPA.
Can't quite tell in the picture. But use a pencil eraser on any of the copper contacts you can get at without harming the switch.
underthetire
Sep 23 2010, 08:50 AM
Just make sure if it has plastic in it to get plastic safe contact cleaner. OHHH I have stories about that... Also, soaking in Coca Cola works well to
