Full Version: Lugs or Studs?
G e o r g e
I have some 6.5 X 15" Minilites less the lugs
I know or believe that they used a lug with a special washer, but have had no luck in finding any ( or at least for a reasonable amount of coin ), anyways what would be a safe and practical way to use these?
Is it really safe to have them reamed to accept the cone lugs or nuts?
any and all insight appreciated
edrotol
QUOTE(George H. @ Sep 22 2010, 06:13 PM) *
Pm sent
Sleepin
Check out Gint's signature George, there is a link on there with that info IIRC. wavey.gif
Sleepin
NM... check here:
http://www.914world.com/bbs2/index.php?showtopic=69869&
DanT
If they are in fact original real Minilites...it is not a good idea to try and machine the lug holes. A good friend of mine is a machinist and said that he had seen this done back in the 80s and that the wheels are too brittle to allow this to be done and have a safe wheel afterwards...
mounting flange ends up too thin,
go with lugs bolts with the proper washers or you could have a machinist make you a set of washers to work with stock type lug bolts or you could got with studs and stock type lug nuts and the custom washers....
