I am in the process of removing the remainder of the driver's side jack point and have become very aware of how hard it is to get to all the areas with even a dremel and most likely later a welder. The passenger side was easy since I had the "luxury" of having to remove the inner dogleg and inner wheel well as a result of hell hole rust.
What is the trick if the jack point is all you have to remove?
