QUOTE(Spoke @ Sep 27 2010, 09:29 AM)
QUOTE(yrret7 @ Sep 27 2010, 11:49 AM)
The issue is that the hood just about touches the fender on one side and has a half inch gap on the other side. In order to move it over I had to enlarge the holes in the hinges that bolts to the hood. The issue now is the play from the pivot point on the hinge. With the hood off and the spring off there is half an inch play. What to do. ?????
Thanks for all your replys!!!! I will try putting washers tonight and see if it helps.
j
The hinge support plates that the bolts tie into are adjustable. If your hood is low or high some adjustment is had with the support plates.
Show a pic or 2 so we can help you better. We don't like to read around here.
Thanks for you reply!!! It's all apart now but someone has posted some pictures of the hinge and bolt. The up and down movement of the hood was ok . It's the side to side movement thats not. I have inlarged the holes in the hood to be able to shift it over to the side . The issue I was having was the hinges had a lot of play at the pivot point. Someone just posted after you stated that this is normal. The fender was replaced at some point. It looks like if I can get it centred the gaps will be right. I will find out tonight when I reinstall the hood. I thought the hinges would not have any play!!!! I don't know how to post pictures yet. I will try to figure that tonight.
I'm super impressed buy the amount of help that I have received. What a great group that I joined!!!!!
