Help
Search
Members
Calendar
Full Version:
Front cross member from 911
914World.com
The 914 Forums
914World Garage
Sep 27 2010, 06:05 PM
Will an aluminim front cross member from a late 70-early 80's 911 fit my 914? Thanks, Mark
messix
Sep 27 2010, 06:15 PM
yup
Sep 27 2010, 06:27 PM
yup
But i'm not a fan, FWIW ... I've seen them flex.
The stock (or 911) steel unit works just fine and the weight savings are marginal at best and at one of the lowest points in the chassis.
I sold my aluminium one years ago and went back to a steel crossmember.
d914
Sep 27 2010, 06:28 PM
yup
sixgt
Sep 27 2010, 06:35 PM
yup, and if you get the cross member make sure you get the two braces that bolt to it. On the steel cross member they are welded on.
Sep 27 2010, 07:38 PM
QUOTE(sixgt @ Sep 27 2010, 05:35 PM)
sean_v8_914
Sep 27 2010, 08:18 PM
where did it flex? under what conditions? how were you witness to the flex event?
Spoke
Sep 27 2010, 08:33 PM
The rack/master cylinder protection plate from the 914 will not fit with the aluminum crossmember if you're attached to keeping the plate.
Sep 27 2010, 09:35 PM
QUOTE(sean_v8_914 @ Sep 27 2010, 07:18 PM)
I saw it. Brad saw it. Rich Bontempi saw it.
Moving the steering left and right you could see it twist....
click here
Invision Power Board © 2001-2024
Invision Power Services, Inc.
