QUOTE(mikea100 @ Sep 28 2010, 04:07 PM)
Thanks George,
The reason I was asking about the hub is that I have a pair of Brembo calipers from 968. Is there any way I can use them in 914?
Thanks,
Mike
QUOTE(dr914@autoatlanta.com @ Sep 28 2010, 05:32 PM)
no and no totally different setup
QUOTE(mikea100 @ Sep 28 2010, 01:24 PM)
Just wondering if it's possible for DIYer to install steering knuckle and front hub from 944. Will I need control arm from 944 also? Has it been done?
Thanks in advance,
Mike
Yes you can use them. You have three different methods.
You could go 5 lug with a later 911 SC suspension with 3.5" spacing on the struts caliper ears. Then redrill the current hole spacing from 3.7 to 3.5 on the caliper. (have a machinist do this) There is plenty of material to do this mod, some people dont agree with it.
OR
if you want to stick with stock suspension, you will have to go with a set of monoblock adapters, a few places make them will cost you around 150 a set. You then also have to machine off the caliper ears so you can bolt on the adapters (more $$) Then you will also need to figure out a rotor setup, since I believe all 968 calipers are vented, you then have to figure out how to get a 911 rotor on a 914 strut (even more $$$)
The other option is a combination of the two above, you buy a 3" 911 suspension (70-75ish) Then do the monoblock adapters. 911 suspension is already setup for a 911 rotor so it makes it all alot easier
Before you start dropping $$$$ on a project, figure out what you want to do with the car and buy accordingly.
Another thing to note is what wheels you are going to run. You can fit 16in fuchs over 968 brakes for sure. 15in wheels get close so someone will have to chime in if they fit.
