Bleeders. $150.00 for a new pair in the proper location.
Then they will be dual bleeder calipers like the late 914 models.
Good score. Those are selling for $1,200.00 with the mod. and all gussied up.
Same piston and pad size as the 911 rear caliper. 308's are vented so you can use a 911 vented rear rotor and either space the caliper back 5mm or put a 5mm spacer under the rotor hat. If you space the caliper back it may rub the arm I think I have a thread here somewhere about the mod. needed to the inner adjuster tubes.
