QUOTE(underthetire @ Oct 3 2010, 10:20 AM)
Pretty much run like hell from anything that has the Empi name on it.
Not true with the HPMX carbs.. Out of the box new Webers and the HPMX EMPI carbs both have issues, the difference is the HPMX carbs have issues that are easy to overcome.. The weber issues are in their castings and can't be repaired generally.
I have been using the HPMX carbs exclusively since 2007 with excellent results. By the time we modify them they end up costing MORE than a set of new webers, but thats fine.. In 2007 I tested 20 pair of new weber carbs, we had a 70% failure rate from those tested, 50% of them had porous castings that dumped fuel when the engine was warmed up, after it had been shut down.
I have compared the two back to back on the same engine no less than a dozen times, I'll post some dyno graphs tomorrow. The BSFC values were better with the HPMX carbs, AFR was more stable and progression was smoother.
Don't expect to bolt ANY of them on to an engine without modifying them off the shelf. Float heights, loose components, butterflies that aren't aligned and tons of other issues are the reality. if you buy a new set of HPMX carbs, or new Webers have them shipped immediately to Art Thraen before you even install them. Art will make them the way they should be and they'll install like a swiss watch. If the carbs have issues Art will identify these and save you lots of hassles.
This is what we do... I have had two bad sets of HPMX carbs since 2007, they run so good that Blake had them authorized for use in SCCA E and F production engines and he'll be running a set next year in E Prod.
Dells... Dells are the cats ass, I run them on every carbureted car that I own, mainly because I can tune them to perfection and love the progression circuits. No HPMX or Weber compares with a Dell..
