When I started my 2.0L FI this morning, there was a bit of oil smoke out of the exhaust, but this stopped after the car had been running for a few seconds.
The green oil warning light on the dash was flickering - it doesn't normally do that. I also have an oil pressure gauge which showed 60psi (as it always does when the engine is cold) - so the flickering was puzzling.
The oil light continued to flicker except when accelerating, until the engine was warmed up, at which point it didn't flicker anymore, accelerating or at idle. The pressure gauge showed about 12psi at idle and 40psi at 3000rpm.
I thought the oil light indicated low pressure ... so why doesn't its behaviour match what my pressure gauge says? Have I got a bad sender, or is this something more sinister?!
Thanks.
