QUOTE(brettm69 @ Oct 3 2010, 06:11 AM)
Will the 901 be able to handle that 3.2?
Brett
Here's my free advice........
A 901 can survive, but it depends upon a few factors:
1. How is the car to be driven?
2. What is the condition of the transmission?
3. Is the transmission improved or modified?
In my experience, if the car is a street car and driven with some form of prudence (no burnouts, no pounding through the gears, no sudden loading/unloading of the transmission (sudden slip then sudden grip)), then the transmission should last a good long time as long as the transmission starts out in good to great shape.
If using for track work, the 901 may find that it is up for a challenge. Sudden loading / unloading of the transmission (like driving on the alligator strips, rumble strips, or curbing) will shorten the life of the gears. The torque of the 3.2 will eventually wear out the transmission.
If the transmission is improved/modified (billet intermediate plate or steel reinforced intermediate plate) and all new components are used in a good 901 box, the transmission can be made to survive. Spray bars can be used to help with lubrication and coolers can be used to remove heat build-up. The transmission will still require periodic rebuilding depending on how it is used.
The failure we saw was with gears. We broke teeth off of at least 4-5 sets of 4th gears before converting over to a 915 transmission. Since converting, the only failure was an improperly set ring/pinion that caused erosion of the ring/pinion set (thanks PMS).
A 915 box can be made to work as well and will offer some more durability, but they too have some limitations and are all getting older as well. The 915 is more expensive to convert and to rebuild (and they will all require rebuilds as well). Recall that the factory changed to the g50 with the 3.2 in 1987 and there was reason to do so.
My street car (84 euro 3.2) is using a 901 with a billet intermediate plate. The trans was fresh when I installed it 4 years ago and I have no problems with it. I don't baby it, but 1st is only to get rolling.
