QUOTE(ArtechnikA @ Apr 18 2004, 09:09 PM)
QUOTE(monkeywrench @ Apr 18 2004, 04:12 PM)
What Brands do members use/recomend?
BG44 and LubroMoly VentilSauber in the gas, LubroMoly MoS2 in the oil.
I'm going to run the MoS2 for the first two sumps om the "NEW" engine, hoping it helps the cam live.
BG44 is the only thing I would ever put in the gas on one of my cars, but I have used the ventil sauber to claen valves by allowing the car to suck it in through a vac line and letting it sit on other cars.
(Lubro Moly has instructions for doing this IIRC. BE
VERY carefull doing it lest you cause engine damage)
So basically I agree!
I usually run none, but when I do use something these three plus GM EOS are the only things I would ever consider.
