Ok this one is a bit odd. Every now and then the idle will be normal. MOST of the time (about 95% of the time now) the idle falls to about the bottom of the tach. It does idle, and it's not rough surprisingly, but it's way off. Other times it idles where it should be.
If it idles that low for TOO Long the engine eventually dies and then it's a pain to start. It'll be at it's worst in traffic. For instance this morning on the way to work it idled that way. If I give it NO gas and just let it idle it eventually dies no matter how much gas I start to blip at it and just quits on me. I can then hold down the accelerator, start the car and we're back in business like nothing happened, although it'll take a bit longer to start than usual (few more cranks).
Now, another strange thing, in the mornings when it's warming up, I could go inside, make a cup of coffee, make lunch, pay my mortgage, do a rain dance, do some jumping jacks, do a lap around the block, come back and it's idling just fine. It appears only do have the issue of dying on me after the engine is warm, that's when it gets "hard to start" again. But if you turn the car off by key and turn it on it'll start right up. Weird eh?
Cold high idle appears to be fine.
It's a bit odd. And again, I have no issues with it at speed she runs like a champ. Just this weird idle. I think if I can get this sorted out i'll be a happy camper.
Things I have done (and it's done this since I had the car) recently
- Valve Adjustment
- New plugs
- New wires
- New cap
- New rotor
- New points
- New harness
- Lots of new grounds
- Tested TPS
- New swear words LOL
- Set the timing as well (which is pretty much spot on)
It did this before i did all of these things, and sometimes is better than others, but most the time it's inconsistent and floating at the bottom of the tach. Not sure if the timing would have anything to do with it, I do not have a fancy meter to check the dwell and all those cool things. I do have a timing light that I used though.
Feelin' nutso.
(edit) here is a video. (click it and itll play)
