I'm having an issue with the AAV. When the car is started it reves up to 3000rpm and does not want to go down.
If I clamp the hose from the aav to just about closed, it will bring the idle down to about 1200 rpm but i must release the clamp a bit to keep it from stalling. I figure the AAV is toast.
I tried to connect the aav to the battery and it gets hot but does not seem to close the air off enough. It might reduce it by 15%
When it works correctly how much should it close off the air? 50% , 95%.
How long will it work for? Until the engine is warm and then shuts off?
When I first got the car someone had unpluged the temp sensor and jamed a plug in the hose to stop any air flow. I found this out when i disconnected the hose comming from the AAV and tried to blow through it and it was pluged.
The car would run fine when it was warm but you would have to feather the gas until it was warm.
