QUOTE(Jesse @ Oct 4 2010, 03:27 PM)
while working on the headlights "we" left the key in the on position. With the Sterio blasting i didnt notice the fuel pump. What i did notice was a puddle of fuel under the car.
I think the fuel got in the oil so first ill change the oil and filter.
anything else i need to do before i try to start it?
Another thought, you might not even have a fuel leak, the puddle could have just been from the fuel pump pushing enough fuel into the crankcase by whatever means to the point where it started to leak out.
Reminds me...
I once had a similar and really strange issue with a jeep i used to own. During the winter I had left it running in the parking lot of my work to warm up while i went back inside. I had something come up so my jeep got left running for about 40 minutes, or at least i thought it was running. I came back outside to find it had for some reason stalled. Here is where it gets strange, for some reason the fuel pump did not stop running after the engine stopped even though it was supposed to, and presumably one of the injector banks was stuck on because it had managed to get fuel everywhere. It was all over the parking lot and you could smell it from 50 yards away however after towing it home and getting everything cleaned up i was unable to find a leak anywhere in the system. I think what has happened is that it just got enough gas in the crankcase to start leaking out of somewhere.
After draining all the oil and at least a gallon of gas out of the crankcase it started up with no issues and i was never able to find any gas leak or reproduce the conditions that caused the fuel pump to keep running after the engine had stalled.
Very strange
Also very dangerous, find your problem.
