As it is most likely going to be quite some time before i have fully tested and am ready to sell the d-jet replacement Megasquirt boards i am working on I am wondering if there is any interest in another solution I had previously thought of but passed over.
Basically its a simple PCB that solders to the d-jet ECU connector and brings those pins out to connectors on the PCB for easier attachment to a Megasquirt or other ECU. People that have already done Megasquirt conversions using the stock wiring harness should know how much of a PITA soldering wires directly to the pins on the connector is. This would allow easier installation as well as a sturdier connection.
The board would be silk screened with identification of the various pins and i am thinking about adding locations for a pull-up resistor to be used when people want to use spark with a dizzy trigger as well as a location for a resistor to ground the TPS signal for anyone that wants to go without a TPS. I am also thinking about adding a circuit to properly fire the stock injectors without having to bring the grounds back to the ECU, but I am iffy on that at the moment.
I know a few people already run MS conversions and i am sure a few more will attempt it before my PnP boards are ready, so i figure something like this might come in handy.
