matteyp
Oct 7 2010, 08:45 PM
Does anyone know if the single barrel weber carb manifiold used on the 1.7s would fit on the 2.0
kphimself
Oct 7 2010, 08:52 PM
QUOTE(matteyp @ Oct 7 2010, 10:45 PM)
To my knowledge it will, i have dual single weber carbs that were on a 2.0 and they fit on my 1.7.
r_towle
Oct 7 2010, 09:09 PM
bolt patterns are different, but a drill can fix that.
Port size and shape does vary a bit, you can port match it if you care.
Should fit, with some effort.
Rich
kphimself
Oct 7 2010, 09:14 PM
Did they change that pattern on them at some point? Mine bolted right up, unless the guy i bought them off or had a 1.7 and thought it was a 2.0. I feel bad, sorry if i gave you some bad info.
r_towle
Oct 7 2010, 09:20 PM
2.0 is a three bolt intake. (Wider position of the outer ear studs)
1.8 and 1.7 is a four bolt intake (two in the middle, outer ears are about 1/8 inch closer)
Some manifolds have three bolt holes in the middle and they have oval holes on the outer ears so they fit on anything...
Rich
jaxdream
Oct 8 2010, 08:29 AM
Was the single barrel weber a 34ICT ??? Smaller carb , shorter intake length stack.Check to see if it clears enough , a 34ICT on a 1.7 is minimal as it is , on a 2.0 l it wouldn't be quite enough , general / popular thought.
Jack / Jaxdream
