QUOTE(porschetub @ Aug 22 2018, 01:15 AM)
Seems when they are shite they don't work again after TLC mine was no better and still had a dead pump feed,got a reconditioned unit from a very good seller on here and all is well.
Its a fairly simple board. The idea for cleaning and soldering all the rivets is a good one, as well as checking resistance from pin to pin. If there is a break in the copper somewhere, or corrosion, it should become apparent with a resistance test.
If the VR that should be arriving today does not fix my charging system issues, I'm going to pull the board and try to rehab it over the weekend.
Zach
