a 914 that was going 185 mph! That's right, 185! Buried the speedo (the last mark is 180).
Seriously. Just this afternoon. More than once. Redline @ 6500 rpm, 4th gear 930 trans. Screamin'!
Normally aspirated 5.7L, 429rwhp @ 6000 rpm, Sheridan Body, big ass tires.
Strapped down on a Dynojet for tuning. Omg what a rush standing right next to it so I could see the dash!
I forgot my camera.
The white LS6 914-8 is finally healthy enough to drive again. Its been at our shop since the Sunday after Hershey in April.
We started out by fixing one broken and one pulled rocker shaft bolt that the owner incurred on his way to the swap meet.
By the time we were done, the camshaft, rockers and valve springs had been changed. The crankshaft was removed and re-ground, and new bearings installed along with a new oil pump.
Thats just the engine stuff. We also fixed the hydraulic clutch so it works as intended, wired the starter and kill switch circuits so they don't have excessive resistance, replaced the leaking radiator, eliminated the toe-out at the rear, and so on.
I'll post some pics of the engine rebuild from the shop tomorrow.
