QUOTE(DrifterJay @ Apr 19 2004, 10:44 AM)
wtf is this!
well - what it's -not- is 1 picture of two turbos. it's two pictures of one turbo.
have a look at the -identical- random nicks and notches on the ports and flanges, and the obvious "cut and paste" line where the parts overlap.
wouldn't mind knowing more about them, assuming it's just a quick way to create an image. mfg name, model number, inlet and outlet turbine housing specs...
and while you -can- turbo a 914, it's -not- just a matter of blowing pressurised air into the throttle body, and the firing sequence of a boxer 4 makes trying to mount one turbo on each side of the engine quite a challenge.. 6's can get away with it because there are 3 equally-timed ignition events on each bank - not so on a 4...
