QUOTE(DblDog @ Oct 13 2010, 11:23 PM)
Dr. Évil et al....
In the shop where all these parts are stored, there are a lot of parts for 944's. So I checked the part number: 088 409 121 is for a 944 diff....mystery solved!
Any more thoughts on the case number?
Thanks for your help.
I was trying to read the part number on the diff, but couldn't quite make it out. Glad you figured it out. It looked like a Porsche diff, but I didn't know what it was.
Regarding the case number, what I say below is total speculation...For the type "914/01" transmission (used in the 914/6), when it had an LSD installed, it included an extra "10" stamped. The standard open diff version of the 901/01 didn't have the "10". It's absence indicated an open diff. I believe that the "10" didn't just indicate that it used a LSD, but that it was an 80% lock LSD.
I think that that early Porsche LSD could be configured for other locking factors. And that while "10" = "80%" and that 80% was the standard value, there may have been other values that they might have delivered. Or if not delivered as stock, then could be done custom (such as on factory race cars?)
Now, for the type "914/11" (tailshift used in the 914/4), when it had an LSD installed, based upon the information I have seen, it has a "B" stamped in the second position. The standard open diff version of the 901/11 would have an "A" stamped in the second position. So you have "HA" and "HB". But there seems to be no indicator of locking factor for the LSD.
My guess is that maybe when they installed a LSD in the 901/11 that they may have sometimes? always? also included a code to indicate the locking factor.
Now, on the type "901/12" (later side shift used in the 914/4) they used an even slightly different serial number pattern. They still used the "HA" vs. "HB" to indicate open vs. LSD, but on the 914 Wiki page I linked to earlier, you can see a photo of a type 914/12 that indicates it has a LSD, but there is no other stamping to indicate something such as a locking factor.
So in short, my speculation is that the case you had originally had a factory LSD. That it may have been the common/standard unit with an 80% lockup factor and that whoever stamped it that day included the "10" to indicate the lockup factor.
But then again, I might be totally wrong.
Regardless, I was curious to see the photo as the best we can do is to look for a number of examples today and see how they were stamped by the factory.
