tracks914
Apr 19 2004, 03:58 PM
I made an engine stand hub for my T4 1.7. It worked like a charm. It has a nice fit on the transmission spigot.
My buddy is doing his 2.4 for his 911 and wants to borrow it. Is the flange the same on the two engines? Will it fit?
Tx
Doug
tracks914
Apr 20 2004, 05:26 PM
Before this gets buried on page 4.....anyone?
Mark Henry
Apr 20 2004, 05:34 PM
Your overkill stand should work fine.
Rusty
Apr 21 2004, 02:37 AM
Let's see the one you made!
-Rusty
Mark Henry
Apr 21 2004, 05:16 AM
He posted a pic quite a while back. It was a homemade (work
) head that was total overkill, on a V8 stand.
If I remember correctly.
Rusty
Apr 21 2004, 06:51 AM
My bad. Sometimes I miss a lot of stuff.
-Rusty
maxwelj
Apr 21 2004, 07:32 AM
I used a VW head from JC Whitney, thinking I would just modify the part that goes into the base, but it happened to fit as is. I did have to grind on the bolt flange a little to get it to clear the ridge on the block, however. It bolts to one of the case halves only. I'm not sure whether I could put the flywheel on, but it seems to hold my 6 OK. And for less than $50, I'm happy!
tracks914
Apr 21 2004, 02:08 PM
Here is a picture of it. I really just wanted to know if the flanges were the same size.
tracks914
Apr 21 2004, 02:09 PM
and another with it attached to the T4
tracks914
Apr 21 2004, 02:11 PM
And of course with the engine done and dressed. (just cause I like the look of it)
Mark Henry
Apr 21 2004, 02:38 PM
You could mount the whole 911 on that!
Yes the bellhousing flange is the same.
