QUOTE(SirAndy @ Oct 13 2010, 11:13 PM)
QUOTE(ppetion @ Oct 13 2010, 08:08 PM)
is that the way hey should stay?
No. Unless you like the smell of hot oil and exhaust gases inside your car.
If you still have the flapper valves on your heat exchangers, you can add the factory hose back on there.
If not, you can cap them off to prevent exhaust fumes from entering your cabin.
Without the correct hoses connected to them, you will *not* have any heat in the car.
ok, I am a newbie, please be a bit patient with me
If i understand right, if i dont put the factory hose on those pipes, i will have gas mell in the cabin.. and I will have no heat. did i get this right?
s far as the pcv valve, it can be connected to the flepper valves... i am not sure what the flepper valve is.
