Razor, I know that you have told me this stuff before, but could you remind us what carbs you are using? What kind of linkage? I *think* that I remember you saying that they were dual IDF 40s, but my memory is more like swiss cheese then cheddar, you know?
If they have been sitting unused for a year (it really *is* abuse to let them sit) they may need to be cleaned and rebuilt. Ethanol rots WAY quick and will gum up the passages.
If they are IDF carbs, there are 4 studs per carb that hold the carb to the intake runners. Depending on the linkage type you are using, there could be one or more small joints that need to be unbolted to free the carb from the linkage. Open up the engine lid and it is pretty easy to see what you need.
You have changed plugs and wires. Have you confirmed that you are getting spark? The easiest way to tell it to hook your timing light up to each plug wire and confirm that it makes the timing light flash. You have probably done this, but the test is too easy not to mention.
Have you pulled out the idle jets and cleaned them with carb cleaner and compressed air? Also, put the nozzle of carb cleaner into the port for the ilde jet in the carb and soak that too, then blow it with air. It might clean the gum out of that circuit w/o needing to remove the carb.
But, we are gettign into the "winter project" months. This is a prime time to pull the carbs and tear them down for a full on rebuild. They *will* thank you for it, and it is not hard to do. I actually tend to enjoy it.
Search for my thread on soda blasting carb bodies and Mark's thread on using Pine Sol.
Zach
