QUOTE(john rogers @ Oct 17 2010, 10:08 AM)
If you buy the lights and they come in a box like the PIAAs I use, they have very complete instructions. I bought mine from ORW in San Diego and they do installs for those that don't want to try electrical stuff themselves.
Here is the link for the CA vehicle code covering lights. Since the car is "old" you can generally get away with a little more.
http://www.dmv.ca.gov/pubs/vctop/vc/tocd12c2a2.htmThis will allow you to decide what you want to run.
Seems like you all may have a misunderstanding of the law. Assuming that the information on the website above is correct and complete, I present the following:
First, the maximum number of lamps.
V C Section 24405 Maximum Number of Lamps
24405. (a) Not more than four lamps of the following types showing to the front of a vehicle may be
lighted at any one time:
(1) Headlamps.
(2) Auxiliary driving or passing lamps.
(3) Fog lamps.
(4) Warning lamps.
(5) Spot lamps.
(6) Gaseous discharge lamps specified in Section 25258.
For the purpose of this section each pair of a dual headlamp system shall be considered as one lamp.
© Subdivision (a) does not apply to any authorized emergency vehicle.
Amended Ch. 234, Stats. 1976. Effective January 1, 1977.
The controlling language being in bold above. Also, I will omit the emergency vehicle language from the next citations, as they are the same.
Then, the site makes a differentiation between driving lamps and fog lamps. Here is the language of each:
V C Section 24402 Auxiliary Driving and Passing Lamps
24402. (a) Any motor vehicle may be equipped with not to exceed two auxiliary driving lamps mounted on the front at a height of not less than 16 inches nor more than 42 inches. Driving lamps are lamps designed for supplementing the upper beam from headlamps and may not be lighted with the lower beam.
Any motor vehicle may be equipped with not to exceed two auxiliary passing lamps mounted on the front at a height of not less than 24 inches nor more than 42 inches. Passing lamps are lamps designed for supplementing the lower beam from headlamps and may also be lighted with the upper beam.
Fog Lamps:
V C Section 24403 Foglamps
Foglamps
24403. (a) A motor vehicle may be equipped with not more than two foglamps that may be used with, but may not be used in substitution of, headlamps.
On a motor vehicle other than a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 30 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
© On a motorcycle, the foglamps authorized under this section shall be mounted on the front at a height of not less than 12 inches nor more than 40 inches and aimed so that when the vehicle is not loaded none of the high-intensity portion of the light to the left of the center of the vehicle projects higher than a level of four inches below the level of the center of the lamp from which it comes, for a distance of 25 feet in front of the vehicle.
Amended Sec. 20, Ch. 451, Stats. 2003. Effective January 1, 2004.
If I follow the specifications of the vehicle code, I can run the following:
- Head lamps
- Driving lamps 16" off the ground, only with the high beams. At 24" inches above the ground I can run the driving lamps with low or high beams.
- Fog lamps between 12 and 30 inches off the ground, and only used with low beams.
- I can not run the driving lamps and fog lamps at the same time.
Therefore, based on the above referenced vehicle code, I can only have 4 lamps lit at any time, and they have to be in the combinations listed above.
