NC_Colfax
Oct 17 2010, 07:28 PM
Looks like I am need some replacement parts as I start the resto on my 1973.
The P.O did a 5 lug rear conversion but I don't know what parts he used. I want to get replacment pads and rotors. I may even have the calipers redone.I am not feeling the red paint job.
Here are a few pics...
Caliper reads ATE 13
Also I had no clue if the Fuchs on my car were real so with the current thread I pulled them off the check....
Best I can read the Part # 901 361 012 06
Which by the listing in the other thread shows it to be a "real" deep six.
Can someone explain the difference between the flat and deep styles??
Is one better than the other or worth more??
Thanks...this forum has been a great resource
McMark
Oct 17 2010, 07:41 PM
Stock rear brakes. Nothing upgraded, just redrilled for 5 lug. It's a perfectly fine way to make the swap. Just order parts like any other 1973 914/4.
NC_Colfax
Oct 17 2010, 07:49 PM
QUOTE(McMark @ Oct 17 2010, 09:41 PM)
You know I should have noticed that....
Could I use 914-6 rotors instead of re-drilling -4 stuff??
McMark
Oct 17 2010, 09:03 PM
Yes, if you've got $ to burn. 914/4 rotors are about $50 + machining. 914/6 rotors are about $100 each.
sixnotfour
Oct 17 2010, 10:54 PM
worth more
veltror
Oct 18 2010, 02:57 AM
QUOTE(McMark @ Oct 18 2010, 04:03 AM)
But does that not mean that the disc needs to have 5mm taken off it? Something Eric said...
jaxdream
Oct 18 2010, 09:07 AM
No to the 5mm removal,that's not the case you have . The PO did a redrill of the -4 rotors , like McMark said , you get -4 rotors as any other 73 ( rear ) and have a machine shop redrill for the 5 on 130mm bolt circle, standard 73-4 calipers are what you have , plenty adequate for a -4 braking purposes or you can hunt down the -6 5 lug rotors and spend the money that way , may not be cheaper . Perform a brake job on the rear as usual with a 4 lug setup. Show some pics of the hubs with the rotors off , that will tell you if the -4 hubs were redrilled , studed ( some differing ways to do that ) or if you have 911 hubs installed, nice set of wheels there , may be worth hanging onto , check the different wheel threads ( search is your friend ) to inform you of the differences of the 911 Fuchs .Good luck ....
Jack / Jaxdream
veltror
Oct 18 2010, 01:40 PM
hmm i have the 914/6 discs so do I have to turn these down 5mm sorry for hijacking this thread
McMark
Oct 18 2010, 01:52 PM
The 5mm thing is for upgrading your stock rear calipers for vented rotors. You need to do nothing, IIRC.
JRust
Oct 18 2010, 02:11 PM
Deep sixes are definately worth more. Very close to the 5-lug Mahle Gas burners in value. Bonus to have them on your car for sure.
Eric_Shea
Oct 18 2010, 02:28 PM
If he buys 914-6 rotors he should have them shaved. Only a couple mm thought, not 5mm. And it's the edge so, diameter (I believe that would be a total of 4mm off the diameter).
I agree with McMarky... 914-4 rotors should be less expensive even with the extra machine work needed and, the mounting screws should match the hub (if the 5-lug was indexed properly without removing the mounting holes).
NC_Colfax
Oct 18 2010, 02:57 PM
Hey thanks for the replies.
Looks like I am going to order a set of 914-4 rotors
I work in a machine shop so the CNC Trac Mill should have not problem with the 5x130mm pattern.
I was very happy to find out I had real Fuchs wheels. After all the BS I found on this car it is just good to know.
