michaelt55
Oct 23 2010, 04:56 PM
Been trying to sell this car to a motivated younger, healthier 914 addict.. I am selling my 72 Buick powered 914. Its registered in Texas and I have a Dr Evil new trans, Rennshifter and West shift kit to go with it. Its outside Houston Texas and right now am asking $ 7.5k for it . I would sell the car without the trans, shifter and west shift kit if asked but it would be cheaper and more cost effective for you to buy it all. I need the space in the garage badly, my SRT8 Challenger is sitting under the patio and my garage is in terrible disorder.
The car has:
BODY
-Rayco FRP front fenders
-Mitcom 916 rear quarter panels
-P.B. Tweeks FRP flared rocker panels
ENGINE/DRIVETRAIN
-1970 Rover/Buick all aluminum 215-V8
-STD bore, 10.5-1 (stock) comp ratio
-Cyl heads-ported exhaust ports, 3 angle valve grind with hi-retainers-shaft rocker stands shortened .060"-pushrods shortened .125" for geometry correction.
-Camshaft-M-488 custom ground by Shadbolt engineering(Vancouver B.C.) C/W hydraulic lifters
-Spheroidal graphite iron crankshaft, 5 main journal center, thrust mains, .010" under - rods ground .001"
-Hi volume oil pump, Buick v8 filter housing
-Facet electric fuel pump-GM canister filter
-Offenhauser alum intake
-500cfm Carter carb C/W electric choke
-Buick distributer with Unilite conversion
-Kennedy engineered product #1000 Rover to Porsche adapter
-KEP 2400# max pressure plate
-KEP throwout bearing
-V.W. 200mm clutch disc
-Custon h.d. radiator w/ twin Spals
-Toyota Corolla heater
ELECTRICAL
-Hella H-4 Q.I. headlites
-Eurolens rear tail lites
-Tach converted to 8cyl
-Mechanical oil pressure and water temp
-Electrical oil temp and cyl head temp
-Alpine CD with JBL audio speakers
-Electric windows
-Keyless entry
SUSPENSION
-H AT H Carrera 19mm adj front sway bar
-Addco 16mm rear sway bar
-140# rear springs (100 stock)
-Stock front torsion bar
-Koni adj front and Koni H.D. rear shock absorbers
-BMW 320i front brake conversion
-Stock Porsche rear calipers
-All four calipers have stainless steel liners and completely rebuilt.
-Adj proporsioning valve
-19mm 911 master cylinder
-All rotors have been crossdrilled
-All flex lines are braided stainless steel
-Pagio performance brake pads, all four wheels
-Carrol Shelby Mini-Europa wheels 7/15 front 8.5/15 rear
-Custom roll bar with rear chassis supports
Lots of extra's, like new bumper top on rear, GT Engine cover, spare front fenders, etc... not perfect but a nice looker and drives well.
email me for any additional info but give me some time as I am working 2 jobs right now and my health is starting to suck...
sooba_dave
Oct 24 2010, 06:05 PM
Neat car! I just talked to Brad Mayeur today about His impressions of v-8 cars. I've been afraid to take the plunge, but I was thinking an aluminum engine would be the only way to go. Your price doesn't sound out of line, but it sounds a little out of My budget. Good luck!
HeloMech
Nov 6 2010, 05:48 AM
That figures... I go to the sandbox and THEN people sell V8's in my price range... DOH!
michaelt55
Nov 25 2010, 02:16 PM
Actually have been driving the car and enjoyed the hell out of it so it may stay with me a while longer if no one comes up with an offer...even bought new mirrors and some other things for it...
Michael
michaelt55
Dec 12 2010, 04:04 PM
QUOTE(michaelt55 @ Nov 25 2010, 02:16 PM)
Michael
lets see...new fuzzies, new mirrors, tune up, thinking of buying another hood and louvering it....
and if I do that, I have to repaint, then I add flares to the front...
and if I do all of that or start doing it..its not being sold...
streetrover
Dec 12 2010, 06:22 PM
Hi Michael,
I'm nearing the mid-point of my rover-914 build. I just wanted to ask about your water pump and distributor. What did you use and how did it fit?
Thanks,
Bob
michaelt55
Dec 12 2010, 10:23 PM
QUOTE(streetrover @ Dec 12 2010, 06:22 PM)
Hi Michael,
Thanks,
Bob
Actually used a stock buick waterpump. The shaft is short enough to fit and my back firewall is notched to allow clearance. I used an Mallory distributor that uses electronic points. With just enough room to spare....
patssle
Dec 16 2010, 07:44 PM
What, finally getting a chance to drive for several months with all this amazing weather well into December changing your mind?
Gint
Dec 16 2010, 07:47 PM
Do you have some real pictures of the car?
streetrover
Dec 18 2010, 08:01 PM
Oh well...I was hoping to find someone who was running the megasquirt2 electronic ignition and injection 'cuz I need some advise in those areas. Thanks and good luck!
Bob
michaelt55
Dec 21 2010, 12:14 AM
QUOTE(Gint @ Dec 16 2010, 07:47 PM)
Gint, explain what you mean by "real pictures"?
Gint
Dec 21 2010, 06:24 AM
You have 3 small pictures here in the ad and no link to others (that I can see). There are 2 pics of the engine and one picture of the back of the car. No interior shots at all. You can't even tell if the front is flared. It looks like it could be, reading from the text indicate it probably isn't, but it's almost impossible to tell by the pics that are available.
It looks fantastic but there aren't enough pics to really tell. Pictures sell cars.
michaelt55
Dec 22 2010, 11:17 AM
QUOTE(Gint @ Dec 21 2010, 06:24 AM)
I will attempt to cure that sometime this week. Thanks for the help Gint.. The car is not flared in the front and the interior shots will also be included.
biosurfer1
Dec 22 2010, 07:34 PM
So it's only flared in the rear? Can you take some good shots of the exterior if thats the case? I've been looking for pictures of a 914 that only had flares in the rear!
michaelt55
May 19 2011, 03:55 PM
bump for interest!
enderw88
May 19 2011, 09:06 PM
QUOTE(michaelt55 @ May 19 2011, 01:55 PM)
bump for interest!
Pictures?
ocs1667
May 21 2011, 10:56 PM
QUOTE(enderw88 @ May 19 2011, 08:06 PM)
bump for interest!
Pictures?
I sent you a PM to contact
Dennis let me know if you rec. it
michaelt55
May 22 2011, 03:09 PM
QUOTE(enderw88 @ May 19 2011, 10:06 PM)
bump for interest!
Pictures?
send me a email and I will send photos and a small video
michaelt55
Jun 2 2011, 03:58 AM
QUOTE(michaelt55 @ May 22 2011, 04:09 PM)
bump for interest!
Pictures?
lets try this..
nope..did not work..how do I embed a video?
michaelt55
Jun 2 2011, 04:11 AM
michaelt55
Jul 11 2011, 04:04 PM
QUOTE(michaelt55 @ Jun 2 2011, 05:11 AM)
so guys...had lots of email, a few calls...
make me an offer that is reasonable.... no
michaelt55
Jul 22 2011, 08:02 AM
QUOTE(michaelt55 @ Jul 11 2011, 05:04 PM)
just for ?
michaelt55
Jul 28 2011, 06:06 AM
QUOTE(michaelt55 @ Jul 22 2011, 09:02 AM)
just for ?
so guess we will be going to other avenues...
michaelt55
Aug 6 2011, 09:01 AM
well..car is going to Ebay soon, make me an offer, I will sell it for less without the Dr Evil trans, Renn shifter, and JWEST shift kit and other extras like GT lid, extra fenders, etc..
I need the room to finish my 1959 chevy truck!!!
Click to view attachmentClick to view attachmentthat LS1 engine I have in the crate in the garage is screaming to get into that beast!!!
michaelt55
Aug 14 2011, 07:27 AM
make me a reasonable offer...its going to Ebay this week.
michaelt55
Sep 4 2011, 11:10 AM
[quote name='michaelt55' date='Aug 14 2011, 08:27 AM' post='1524425']
ok...its on Ebay item #150658665434
michaelt55
Sep 18 2011, 07:08 PM
[quote name='michaelt55' date='Sep 4 2011, 12:10 PM' post='1534429']
[/quote]
well I am surprised...no bids, several calls and offers off the cuff..but nothing solid...after 2 listings...
looks like its staying with me..
AgPete139
Sep 27 2011, 03:01 PM
It's a nice car. I'm not a buyer, just an admirer that lives at 610/290 area. I'd love to come by and see your creation sometime!
Either way, if it's meant to sell, it will. Good luck!
Pete
michaelt55
Oct 5 2011, 08:18 PM
QUOTE(AgPete139 @ Sep 27 2011, 04:01 PM)
Pete
thanks...its just after my accident its really hard to get into a car this low but guess I need to put the extra parts in it and drive the wheels off of it...but thats taking money from my 59 chevy truck rebuild...
michaelt55
Nov 6 2011, 03:18 AM
[quote name='michaelt55' date='Oct 5 2011, 08:18 PM' post='1549975']
[quote name='AgPete139' post='1545342' date='Sep 27 2011, 04:01 PM']
Pete
[/quote]
still for sale guys..
michaelt55
Nov 17 2011, 07:53 AM
ok, its been a busy month, paid taxes, married off daughter
, getting started on new job, etc...
if I havent replied to people asking about the car, please try again..I know its a pain but now I have time to answer questions and post more pix if needed!!
michaelt55
Dec 16 2011, 09:12 PM
Anyone interested???
Stonepilot
Dec 21 2011, 06:55 PM
super nice
michaelt55
Dec 30 2011, 11:42 AM
QUOTE(Stonepilot @ Dec 21 2011, 06:55 PM)
super nice
Thanks, appreciate it!
michaelt55
Jan 20 2012, 01:20 PM
Price drop. $9000 with extra parts or
$7500 without. It's not getting any lower so make a move!
Gotta move it to make room!
michaelt55
Feb 11 2012, 07:04 AM
QUOTE(michaelt55 @ Jan 20 2012, 01:20 PM)
getting emails but not much else.... come on guys summer is almost upon us..its a ready to drive car!
914.SBC
Feb 12 2012, 03:00 PM
What a great price for V8 conversion.
EWPE
Feb 23 2012, 11:50 AM
Please give me a call. PM sent with my phone number.
EWPE
Feb 25 2012, 08:52 PM
Is car still for sale ? Please give me a call 609 680 8800 Thanks Ed
hbgsteve
Mar 7 2012, 05:36 PM
Is it still for sale? call me if it is 707 293 7575
michaelt55
Mar 18 2012, 10:54 AM
[quote name='hbgsteve' date='Mar 7 2012, 06:36 PM' post='1641122']
left you a message
michaelt55
Mar 18 2012, 10:57 AM
ok, last 2 people who expressed interest have been contacted. I need to sell the car as its really taking up space in the garage and I cant drive it comfortably any more due to my medical condition. Come on..lets talk turkey, be reasonable. Hell I will even take trade on some work or parts on my 1959 Chevy Apache!
michaelt55
Aug 11 2012, 11:18 PM
Well...still looking for a new owner...lets talk money, I will sell the whole kit and kaboodle for $7500. Longer you guys wait , the less I will put into the car, I am about ready to place it in storage and wait. Email me with offers but dont be ridiculous or insulting please.
michaelt55
Aug 23 2012, 06:25 PM
seems either no one cares or I am going about this wrong...someone make an offer?
pt_700
Aug 24 2012, 11:13 AM
i'm surprised nobody has scooped this yet. i have way more than the asking into my long stalled project and it's nowhere near complete...
specfordracer
Aug 25 2012, 08:09 PM
Hello, I am interested in your car. I am new to this site but have always thought 914's are fantastic cars. I am interested in a nice driver quality car that is simple and fun to drive. I appreciate your time, thank you, Todd. (609) 805-5964
michaelt55
Aug 25 2012, 10:32 PM
QUOTE(specfordracer @ Aug 25 2012, 09:09 PM)
I will give you a call tomorrow...
michaelt55
Sep 1 2012, 03:57 PM
ok I have again talked to one gentleman in depth, still looking for a buyer...
gandalfthegray
Sep 1 2012, 06:52 PM
QUOTE(michaelt55 @ Aug 11 2012, 10:18 PM)
QUOTE(michaelt55 @ Aug 23 2012, 05:25 PM)
QUOTE(michaelt55 @ Sep 1 2012, 02:57 PM)
Michael, my $7k offer still stands. Let me know if you should change your mind.
michaelt55
Sep 2 2012, 07:01 PM
QUOTE(gandalfthegray @ Sep 1 2012, 07:52 PM)
Will tell you after Todd and I finish talking,
Then maybe a modified deal can be done.
Michael
