you may have the 70-72 style setup. It features a square tubular engine cross member outboard rubber mounts encased in steel and one engine to bar mounting frame. This setup does not use the center so called "hockey puck" rubber engine mounts.
If you need them all of the member vendors have them on the shelf in mass.
QUOTE(kphimself @ Oct 23 2010, 06:16 PM)
I just noticed i don't have motor mounts, my cross member from the engine was bolted directly to the body, is there a rubber motor mount that goes on it? Who sells them?
