Full Version: Front stock sway bar questions
mikea100
1) How long is stock front sway bar?
2) How long are the square ends?
3) How tick is it 17mm/19mm/22mm?
4) Has nayone used Weltmeister? How's the quality, is it better/worse/no diff?
Thanks,
Mike
Eric_Shea
I like the quality better than the welty's but... those are fine as well. Most street driven 914 would benifit from a stock bar and it is all that is needed in 90% of the cases. Get a bigger bar; get a harsher ride.
markb
If you're doing comparisons, check out our GPR Bar.
PeeGreen 914
QUOTE(markb @ Oct 25 2010, 02:09 PM) *
mikea100
Thanks guys, I just bought Welty that came from 930. I wasn't sure if it's going to fit on 914, but after some research I figured that it's one size fits all. For the rear sway bar will definitely keep GPR in mind.
