QUOTE(kkid @ Oct 25 2010, 08:20 PM)
Hello guys,
So I did a compression test for the first time and the numbers are:
#1: 145.5
#2: 135.5
#3: 145
#4: 145
They are almost identical except #2 but later I found the numbers are inaccurate. Yes, I forgot to ask my wife to hold the gas pedal wide open while I was holding the gauge. So here is a newbie question. Does the compression usually go up with the throttle wide opened?
Thanks in advance.
kkid
Hey KKID,
Short answer: YES!!! Open vs. closed throttle can make a BIG difference in your compression check numbers. So, make sure the battery is charged, pull all the plugs, JAM the trottle open with a screwdriver or pliers or whatever will work and take another check on #2.
I'm sure it will be better. That said, unless you are prepping for the National Runoffs, even the 10lbs difference you found should be fine for a daily driver.
You can always make it PERFECT in another 60k - 80k miles....
The question I have: What engine configuation are you running? It seems to me that the 145.5 lbs/in3 is pretty darn good for a 9:1 CR motor. Also, I'm guessing you are running a stock or mild cam.
NO WORRIES, you have a great engine!
Terry
