Full Version: Timing marks
Archie
Hello again group,
I bought a used fan for my 1.7 as the old one was missing some teeth (much like its owner!), but the new one has no timing marks. Questions: Is the notch on the pulley TDC? Does this then line up with the notch on the flywheel? Is the O mark or the line on the fan TDC ? Thanks again.
dlee6204
The "0" is TDC . The line/notch on the fan should be your timing mark.
Drums66
Archie
QUOTE(Drums66 @ Oct 26 2010, 03:21 PM) *
...1st must have the right cage for the squirrel :poke: :idea:
:wavebye:
True! Very true.
SLITS
If you have a 1.7/2.0, the timing mark for 27 degrees is 55.5 mm to the right of the 0 mark.
I don't remember the measurement for the 1.8, but it is 7.5 degrees which would be about 14.? mm to the right.
This is all facing the fan,
