QUOTE(Racer Chris @ Nov 1 2010, 06:51 AM)
Lots of hot rod guys put wide tires under stock fenders. They call it Pro Street.
The existing inner fenders would need to be cut out and the shock tower moved inward.
I already have all the pieces required to narrow the rear pickup points. My raised suspension kit could easily be adapted to the job and standard length pivot shafts could still be used.
Stock axles could be kept if the trailing arms were modified and wheels with greater backspacing were installed.
What, are you shopping for work?
I'm sure you could pull it off.
Here's a pic of the area.....with a nice black rub mark giving some idea of the effected area. (there is nearly 3/4 inch clearance there to the tire...got carried away with low tire pressures.... ONCE.
The area would need a whole of cutting...all structure. Were I to contemplate actually doing this, a rear tube frame and do away with them GD arms all together would get my vote.
