QUOTE(Eric_Shea @ Nov 2 2010, 05:20 PM)
I'm already into this car for way more than I want to be. Suggestions?
Sell it because to do it the Anti-Mickey way is to do what Bruce suggests and, if you think you're already into it for way more than you want to be now...
I hear that loud and clear.
It turns out that 1 of the original bolt holes in the floor pan is still there and in good condition (the one nearest the tunnel).
For the bad one, I am contemplating filling that void with some aluminum, welding it in, drilling a hole, and using some countersink bolts to mount the new pedal.
Sure, it does not remove all the rust in the area, but it is much more sturdy, and will last for many years.
Additionally, it turns out that the bell crank is bent - and that is what is causing the linkage piece to become disconnected when the pedal returns to the idle position. I think a good bend in the oposite direction will solve that problem.
BUT - I would be willing to buy a replacement unit if I could find one. The Pelican Parts Catalog does not have one for the 914 - are we supposed to use the 911 piece?
