So I think I need a little advice from everyone on here with a bit more experience with these things than I have.
I've read info from Rennlist:
http://www.rennlist.com/techarticles/djetronicfuel.htm
and from Bowlsby.net:
http://bowlsby.net/914/Classic/TechNotebook.htm
In the last couple of years, I've driven my 914 infrequently, and I have had an ongoing issue with fuel pumps failing. I am now about to order my fourth fuel pump, and I am quite upset about throwing so much money at a problem that really seems like it should be fixed.
After my last repair (installation of yet another fuel pump) there was a strong fuel smell in the garage. I realized that almost all the hose clamps on the fuel lines under the car (around the fuel pump) were loose and fuel was draining out white rapidly. I fixed this issue and the car seemed to be running great. A few weeks ago I went to start her up and drive away, and by the end of the block I was feeling the typical 'ch-chug-a-chug' for the car dying from fuel starvation. HELP!
I'm determined to tackle this on my own this time, and this is what I have found:
1) Wiring to the pump seems a little brittle, but it appears to be functioning. Turning the key to on before hitting the starter produces 12V at the fuel pump wiring for less than a second. This seems to be working properly, please let me know if this is not correct!
2) Fuel pump will not respond to jumping from a motorcycle batter (12V) so I am assuming it is dead and will order a new rebuilt one. Since I have had two rebuilt fuel pumps from the same place (not a 914 specialist) I was going to order all my parts, including the pump from AutoAtlanta, unless someone recommends something else?
It appears that my previous pump rebuilder sprays the entire pump with black enamel, including the hose nipples. That means dissolved paint is going into my engine! Not bad in small quantities, but flakes could clog the lines...
3) The hoses going from my Air Cleaner up front to my charcoal cannister are broken. Could this contribute to a lack of air in the gas tank to replace fuel as it is pumped out, therefore putting higher strain on the fuel pump and potentially burning it out?
Pic of my hose:
4) My gas tank and sock appear to be relatively clean. there are some small particles, which I might try sopping up with towels in the tank, but it does not appear to need treatment, or even a new sock?
5) Where the hose from the charcoal canister attached into the gas tank filler neck, the fitting appears pinched, but air does appear to flow through it. Is this normal?
6) This is a picture of my fuel filter. This does NOT appear to be the correct filter for a 914? one side is a 8mm and the other is 12mm?!?! You will also note the ARROW showing flow direction points from the 8mm to the 12mm?!?! It was installed on my car in the OPPOSITE direction that the flow arrow shows, with the 12mm side connected to the supply from the tank and the 8mm side connecting to the S on my fuel pump. This to me seems like it might be the primary culprit? Could reversing a fuel filter be that bad?
7) My under the car heater hose is cracked/broken out of place. It is quite possible that hot air was being blown on my fuel pump? This seems like a BIG no-no, but if this was the culprit, I would expect my fuel pump to have failed in the middle of a long drive on a hot day, not on a freezing morning when I am just leaving the driveway? This should be fixed either way.
8) Since I have a 12mm line and a 8mm line at my pump/filter, I am a bit confused, and potentially worried about the hoses hooked up in the wrong order to my fuel pump. The image I found from bowlsby.net was quite helpful:
http://bowlsby.net/914/Classic/zTN_FI_Hose...ump_1970-74.jpg
but it makes me think I am missing #6, the 9mm to 7mm reducing hose. Then I realize I don't even have a 10mm or 9mm, but a huge 12mm. Could my lines be misconnected?
I took this shot of the R-Return line coming from the pump, going to the Y and then it is clipped into the side of the body. Anyone have any idea if this is correct or if this should in fact be my S line? (terrible picture, my apologies!) Perhaps someone could post up a picture of the 9mm to 7mm adapter?
If anyone has the patience to read over any of this, I would be extremely appreciative. I feel like I'm shooting in the dark a bit, with no clear idea of what is destroying these pumps.
Cheers,
Orange71
