QUOTE(jamesjedi @ Nov 11 2010, 01:10 PM)
QUOTE(Garold Shaffer @ Nov 11 2010, 12:56 PM)
My question to you is what do you want a race car for? By that I mean what are your plans? SCCA, NASA, PCA, just for track days, Axing?????
I bought an old Fprod SCCA roller a few years ago for $4500. had everything you needed, even a motor that was DOA. My plan was track days and AXing so I wasn't to concerned about what class it would fit.
So once you know what your plans are then you need to make sure this car (or any other) will fit that need or can be made to fit that need.
I am the same as you, I just want to have a competitive (winning!) autoX car that I will drive to the track, or anywhere for that matter. Racing is not in the budget, but not ruled out for the future.
Well then you will need TWO 914s
I sold the Racecar this spring. While its was awsome fast and great fun I couldn't drive it on the street. I only AX it 10 times a year, hardly worth it to me to have and maintain. So I went back to my 70 914 since I can do both with it.
As others have said it has everything I need. It has gone thru some changes over the past 8 yrs. When I bought it the PO had a 73 2.0L with euro pistions in the car with stock front & rear sway bars and adjustable koni shocks. Here is my short list of mods I have done to it since then:
Replaced front sway bar with 19mm bar
Removed rear sway bar
adjustable rear coil overs with 160Lb springs
tuna can sump pickup
lowered & corner balanced
bump steer kit
oil temp & pressure guages on A pillar
Lemans GTS seats
harness bar & 5 point belts for each seat
Minilite rims with 205x50x15 Kuhmo V710 sticky tires
While I am not the fastest, I think I do well. I know the car can do more with a better driver than me (have seen it done already) I run in SCCA DSP class and usually beat the SRT4 I race against and keep close(under 1 sec) to the WRX guys running in STX the 911 running is BSP. I think that says a lot for a little 110hp 70's car.
While the best thing that YOU can do to be a award winning AXer is seat time! The more the better. Watch, listen, learn from the top drivers where you AX. Once you get to know your car then start making changes to it if you wish, but only one change at a time.
That's my 2 cents
PS My 914 (aka MYGOKRT) in action
