It's got a T1 engine with a cooling system that’s a cross between a T3 and a T4. The engine is cast different with the breather tower over the 2/4 web and the nose is cast more like a T4. 34 PICT carb, stock intake ends but the centre section is different. The entire cooling shroud is steel, even the fan housing. The heater boxes are almost stock but have extra long 's' shaped tubes on the ends. Everything does look factory, serial # CT131429
Jake or anyone ever seen one like it? Industrial engine? Euro or third world?
