ruddyboys
Apr 22 2004, 09:25 AM
I have a short somewhere, figuring that might be why the car wont start I pull all the fuses. I have the fuel pump hooked up to the coil. I turn the ignition on and I don't hear the pump. I try putting in one fuse at a time and then ikt works ( I believe fuse 7). Does this sound right? I figured the ignition wire to the coil went from bat. to ing sw to coil with no fuse?
davep
Apr 22 2004, 02:11 PM
The fuse and relay for the fuel pump is on the relay board in the engine compartment. Hooking the pump up to the coil is a no-no.
